installing 01 SS ls1 gas tank in 95 lt1 T/A ???
i am looking to shed a TA
i am wanting to install an ls1 gas tank and fuel pump
i am wanting to see how i can do this and if anyone has done it
any diagrams ??
thanks
any diagrams ??
thanks
yes this is an 01 plastic one and yes it is lighter thats the reason we are changing it the only thing we are not sure aout are the fuel lines and plugs. i am trying to figure out what we have to do to make it work
Originally Posted by Revelation Z28
LS1 is returnless gas. so you wont be using one of the lines. unless you put an LT1 pump in.
any diagram available??
what about the wiring ?
Originally Posted by Formula350
Why not just pull the whole sending unit out of the LT1 tank and install it in your new LS1 tank? I'm sure at least that part will drop in no problem.
but it is worth a try
anyone else with more info??
Originally Posted by TwoFast4Lv
Actually the return is down by the Fuel filter so it can be hooked up just fine
how did the plugs match ??
Actually if you get the wiring that plugs into the car under the dr side rear seat back it should plug right in
Like I said the only real bonus I see is easy Fuel pump changes
now i need to get aht harness and also figure out the fual lines
thanks a lot for the help bro
