View Poll Results: Longest Lasting Dual Valve Springs?
PRC Duals
17
36.96%
Patriot Duals
21
45.65%
Manley Duals
5
10.87%
AFR Duals
3
6.52%
Voters: 46. You may not vote on this poll
Longest lasting valve springs
Old 05-07-2007, 01:04 PM
nseldy's Avatar
Default Longest lasting valve springs
I'm doing a cam install into my daily driver and just would like to get opinions on the longest lasting dual valve springs. Thanks
Old 05-07-2007, 01:13 PM
Kryckter's Avatar
I didnt see the option to vote for some Comp Springs, I.E. Comp 921's.
In turn, I voted for PRC, TSP has some great deals on em.
Old 05-07-2007, 05:09 PM
bluecamaroz28's Avatar
Glad you didn't list Comp springs cause it's a piece of crap. 918 broke on me and cost me a valve and piston.
Old 05-07-2007, 07:55 PM
DONAIMIAN's Avatar
These are aftermarket parts. Some are expected to fail simply because the aftermarket dosent have big bucks like the OE companies do to dump into R&D.
As to the original poster, spring life depends on a number of variables. One spring isnt neccesarily(sp) going to last longer than the other.
Old 05-07-2007, 09:43 PM
byler900f's Avatar
patriot extremes
Old 05-07-2007, 10:24 PM
Geoff's Avatar
All of the listed springs in your poll are made by the same company. All of the 'gold' springs are the same. The only difference is the finish treatment on some of them and their seat and retainer package. Pick whatever company you are comfortable dealing with and enjoy...
Old 05-07-2007, 10:44 PM
airflowdevelop's Avatar
Pretty Much 100% correct. The best luck I have had is with PAC Springs (Chris Osborn). I have had customers that were changing E* and S* brand springs @ 10 runs because they were junk...now change their PAC's at 300 runs...because they feel guilty, not because the springs are bad... In fact, I have a local guy that gives me 25% on the used pacs...and has never had one fail YET!
Hard to believe, but only a few make springs...for hardcore stuff, PAC is the leader. You watch them on TV every weekend...but never know it.
Dennis
Old 05-08-2007, 02:40 AM
PREDATOR-Z's Avatar
Pointless post.
Springs should be pressure checked once a year or every 15K miles.
when out of spec for said cam then need changing.
Old 05-08-2007, 10:34 AM
nseldy's Avatar
ok, thanks for the input, learn something new everyday!
Old 05-08-2007, 07:25 PM
Juiced's Avatar
Originally Posted by PREDATOR-Z
Pointless post.
Yup...
You put an aggressive enough lobe like a comp CR lobe and it will wipe out a spring in 300-400 miles. And I'm talking 600 seat 1200open pressure triple springs.
Old 05-08-2007, 09:58 PM
CamaroSS's Avatar
Haha, I actually read the poll and laughed. Good catch!
I am going with the PRC springs because they come on the heads haha. That being said, I had no issues with my 921 Comp springs, and I ran a 236/242 .601/.610 for over a year to 7,000rpm. Then I ran a TRex for about 2 months before I spun a rod bearing....nice. haha
Old 05-09-2007, 05:12 AM
cowboysfan's Avatar
agree with some comments posted here. my opinion is, you cant say how long valve springs will last. variables are cam profile aggresiveness, how often do you wot, driving habits, miles put on them in between track use and number of times of track use.... these are some things to think about, just test them at recommended miles and you cant go wrong.. good luck.
Old 05-09-2007, 07:44 AM
ExceSSive's Avatar
Stock with stock cam
Old 05-09-2007, 08:42 AM
slt200mph's Avatar
I put 43,000 miles on a set of Texas Speed PRC platinum dual springs..they were still working well when they were replaced..I need to check them and see how much life was left in them..they were not floating at the 6800 red line on a 233/233 595/595 112 cam ...
Old 05-09-2007, 01:24 PM
ChevyLSXFan's Avatar
PSI LS1511 have used them in my old Camaro with great success. Also, Katech uses them. Enough said
Old 05-09-2007, 04:36 PM
LostCauseZ06's Avatar
i have MAAAANNNNYY miles on my comp 921's
Old 05-09-2007, 05:30 PM
one2run's Avatar
I use the crane duals in mine. Granted it is a small cam to todays standards, but the springs are still in the car pushing 20,000 miles. The car drives as strong as day one of the cam install... somedays stronger, and I beat the snot out of this car!
I am putting in a new cam (profile near the G5x3's) next weekend, and bought the crane duals again so I may reuse my ti retainers. I hope to see the same quality and longevity I recieved from the first set.
Old 05-13-2007, 02:22 AM
ls1f-body's Avatar
i have a friend that has broken 2 sets of patriots on his ms4 cam and it has only run for 2800, so if you are going with that cam i would not recommend those springs
Old 05-13-2007, 09:51 AM
LSWon00's Avatar
COMP 921s here I checked them 3 months ago and they're all fine after 23K on them.
Old 05-13-2007, 10:15 AM
Studytime's Avatar
One set might indicate a defective spring, but two? I'd venture there is someother issue going on here (installation).
These springs are very proven.
Ben T.
Quick Reply: Longest lasting valve springs
