LS2 stroker with L92 heads gasket size
Old 05-07-2007, 02:12 PM
Spinmonster's Avatar
Default LS2 stroker with L92 heads gasket size
Do the L92 heads use a 4.03 bore gasket for use on the LS2 block or does the combustion chamber extend beyond the 4.03 requiring a larger diameter bore gasket?
Old 05-07-2007, 02:39 PM
Stang's Bane's Avatar
I believe the standard bore on a L92 block is 4.065. Someone please correct me if I am wrong. Hope this helps
Old 05-07-2007, 03:25 PM
See5's Avatar
You need at least 4.065" bore gasket which is L92 size. There is really no downside to runing gaskets for 4.125 bore.
I am running LS7 sized .040 Cometics.
Old 05-07-2007, 06:36 PM
LS1TA385's Avatar
Yeah i think the L92s require a 4.000 bore or larger which you are ok with but i think most head gaskets i have seen for these heads are 4.160, i may be wrong though
Old 05-08-2007, 08:42 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Guy, I replied on the other forum as well and sent you a PM. And for the record over here so the answer might spread and be known by all: 4.0x" bore and L92 heads need a head gaskets with a bore of 4.085 or so (GM's gaskets for this ranges from 4.09-4.10"). We keep the Cometic gaskets and the GM MLS gaskets in stock!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Quick Reply: LS2 stroker with L92 heads gasket size
