no tach and car won't run
Old 05-07-2007, 06:07 PM
00 black ram air's Avatar
Default no tach and car won't run
Car is throughing a p0343 cam sensor input high code. I read somewhere that guys were having problems with timing chain sprockets I have a slp double roller you think this is the problem
Thanks
Old 05-07-2007, 10:09 PM
Closed ex-Sponsor Account
autotrix's Avatar
Check to see if you have a input/senor problem or a base motor problem. Check and see if the rocker arms and valves are opening. Try and access a scanner and monitor crank sensor RPM. Hope this gets you goin'
Old 05-08-2007, 10:17 AM
1hotls1's Avatar
If the tach isn't working, its probably a bad crank position sensor. I had the same issue and it was an easy fix.
Old 05-08-2007, 10:25 AM
GuitsBoy's Avatar
If the cam position sensor used to be fine right before a swap, chances are it still is. High input means its always reading a signal from the sensor. Its likely out of alignment and teh sensor is reading the cam journal instead of the reluctor. I would suspect the double roller pulling the cam (reluctor) out of alignment with the sensor.
Old 05-08-2007, 07:58 PM
never mind found the problem
Old 05-08-2007, 08:21 PM
GuitsBoy's Avatar
What was it?
