Hurst Linelock with SJM pre bent lines, need pics
Old 05-12-2007, 01:20 AM
ultraz's Avatar
Default Hurst Linelock with SJM pre bent lines, need pics
I bought pre bent lines for my Hurst line lock, but i lost the INstallation pictures page. I need to see which holes need to be plugged and which ones to use. ANyone with the pictures installed please post them, im looking ot install tommorow.
Old 05-12-2007, 11:21 AM
SJM Manufacturing Inc's Avatar
Looking at the solenoid, with the heat fins facing down at 6 o'clock, a 90 degree fitting goes on the face bottom hole, the other 90 degree goes on the left side. The other two ports (top and right side) is capped off.
Old 05-12-2007, 08:52 PM
ultraz's Avatar
i know it sits on the driver side fender. WHIch way does it point? Are u supposed to be able to read the hurst from the driver side, or the passenger side?
Old 05-12-2007, 09:08 PM
should be drivers side you can read it from.
Old 05-13-2007, 09:29 AM
SLowETz's Avatar
Does this help?
Old 05-13-2007, 06:22 PM
ultraz's Avatar
Originally Posted by SLowETz
Does this help?
I just needed to know which way the lines went and which holes to use. I am still going to keep abs. Thanks though
Quick Reply: Hurst Linelock with SJM pre bent lines, need pics
