can some one please tell me what gasket i need to get for my heads?
the motor is a 408 with -8cc pistons,zero deck, and cam is a 257/266 .643/.622 110 lsa.
i wanna run stock 317 heads for now until i get money for the tfs heads.
i posted the other day about 5.3l heads,but ive decided to run the stock 317's for now.
i wanna be no higher than 11.1 comp.
what gasket do i need to buy??
Adam
Adam
You'll need gaskets bigger than 4.030 bore, like 4.060 +
Always run .030 bigger than bore at least
Originally Posted by PREDATOR-Z
You'll need gaskets bigger than 4.030 bore, like 4.060+
Acturally Pred. A 408 is only a 4.030 bore so a 4.060 gasket will work just fine.
Maybe even look into the GM L92 head gaskets. The bore on the L92 is 4.060 and the gasket works great.
Call one of the local sponsor's.
I perfer SDPC and they can get you a set out right away.
1800-456-0211
thats their number. They are in Tx.
1800-456-0211
