Brake line help!!
i have traction ctrl but the lines from the chasis bracket to the caliper should be the same. my oem line is like 7", the new one i got in the russell kit for a 2002 camaro measures 8" from center of hole in banjo to end of fitting on other end. It's banjo fitting on the caliper end, 10mm x 1.0 bolt goes into caliper. Other end is a straight end, female fitting that's also 10mm x 1.0.
Originally Posted by Stang's Bane
Thanks alot man!! I just need to find someone to sell me 1 single line now
i'm hoping to finish my little brake project by this weekend, if you can't find a single rear brake line by then I may be willing to sell you mine. It's an oem hose, nothing wrong with it.
how much do you want to pay?
