steering whell controls want to use
Old 05-16-2007, 08:34 PM
WS SIKZ's Avatar
Default steering whell controls want to use
i have a kenwood h/u an di want to know if i can still use the steering wheel controls. i heard htere are a adapter but i cant find it. any one got any input 2000 t/a
Old 05-16-2007, 08:40 PM
BJM
BJM's Avatar
You want a PAC-SWIX. I have one and it works well.
Old 05-16-2007, 08:52 PM
Ungrounded Moderator
WhiteBird00's Avatar
The PAC SWI-X is a universal adapter that will adapt the steering wheel controls to almost any aftermarket head unit that has an infrared remote control. PAC also makes adapters that plug directly into the back of certain compatible models of head unit. If your Kenwood has a remote control jack on the back then you can use the PAC SWI-JACK for a direct connection that doesn't require mounting an infrared sender like the SWI-X does.
Old 05-17-2007, 09:24 PM
WS SIKZ's Avatar
weich one would work for me 00 ta with kenwood face
Old 05-17-2007, 10:54 PM
Kage's Avatar
Cool
http://www.pfyc.com/pc/GN8002/CMOTHE...Interface.html
Old 05-18-2007, 07:04 AM
It's not a question of what model of car - it's what model of Kenwood radio you have. You have to find out if your Kenwood has a remote control jack on the back (for use with a wired remote). If it does then you can use the SWI-JACK to connect your steering wheel controls. If it doesn't have the jack but it has an infrared remote then you can use the SWI-X. If it doesn't have either kind of remote control capability then you're just out of luck.
