NEW HID Install questions...
Old May 3, 2007 | 03:27 AM
Mike@ZMS's Avatar
Default NEW HID Install questions...
Basically I got my HID kit last night and I was wondering how to wire it. Im curious about the ballast in particular. Its a two wire loom that comes off of each box (one white wire, one black) Im guessing that these wires get spliced to the stock headlight bulb connectors? One power, one ground. Is there anything else I should be watching out for as far as current overload on the circuit. Should I wire a relay in?
Sorry for the dumb billy questions, its just that electrical crap escapes me. I can turn wrenches all day long, but dont ask me to do more than strip a wire.
Old May 3, 2007 | 03:37 AM
Kage's Avatar
Cool
Tell me you're joking??
It's plug and play nothing to it.
Old May 3, 2007 | 03:54 AM
Mike@ZMS's Avatar
this kit is not so much... its a japanese ballast and german bulbs.. My main question is should I run a relay through it or will it be fine as a straight wire and go? I would rather cover my bases no matter how ridiculous than screw something up.
Old May 3, 2007 | 04:03 AM
Kage's Avatar
Cool
It doesn't matter. Does it look like this?
Post pics i don't see what the big deal is.
Old May 4, 2007 | 03:47 PM
Mike@ZMS's Avatar
I got it installed.. I just didnt want to chance anything... oh well.. thanks for making me look stupid.
The HID install was more straight forward than I thought. I didnt even really look at it before posting honestly. I just dont want to **** up my new ride.
Thanks though...
I do have one more question though... is there any simple way of wiring up the highbeams so that the lowbeams stay on when the highbeams are switched on? Basically I want all four lights on when I hit the highbeam switch. Is this possible?
Old May 8, 2007 | 04:17 AM
Kage's Avatar
Cool
Thanks though...
Stylinconcept give them a call.
Old May 9, 2007 | 12:23 PM
WhiteBird00's Avatar
Ungrounded Moderator
This is quite simple. The headlight dimmer switch connector at the steering column has three wires - yellow, tan, and light green. Just use a short piece of wire to connect the yellow wire to the tan wire. Your headlights will work normally except that the low beams will stay on when the high beams are selected.
Bear in mind that this is only legal if you leave the factory configuration where the fog lights turn off when the high beams are used. You can only have four lights on at the same time.
Old May 9, 2007 | 01:23 PM
Beeler422's Avatar
Back in the staging lane
SVT, you can't have links to non-sponsors in your sig. Thanks.
Old May 10, 2007 | 03:25 AM
Mike@ZMS's Avatar
Thanks WhiteBird... Ill try that.
Beeler, can I at least have my clubs link in the sig? Its not a business, nor is it any sort of profit generating organization.
Old May 10, 2007 | 03:37 AM
Kage's Avatar
Cool
Originally Posted by WhiteBird00
This is quite simple. The headlight dimmer switch connector at the steering column has three wires - yellow, tan, and light green. Just use a short piece of wire to connect the yellow wire to the tan wire. Your headlights will work normally except that the low beams will stay on when the high beams are selected.Bear in mind that this is only legal if you leave the factory configuration where the fog lights turn off when the high beams are used. You can only have four lights on at the same time.
Good to know, but do you need a relay or a fuse for this mod or not?
Don't want to burn my **** up ya know.
Old May 10, 2007 | 07:08 AM
No relay is necessary. This mod just makes the Camaro wiring configuration the same as on Firebirds which already leave the low beams on with the high beams. The Firebird wiring has the low beam power bypass the dimmer switch to ensure they remain on, so this mod just adds the same bypass to the low beam side of the Camaro dimmer switch. Of course, make sure you use a big enough gauge of wire for the bypass.
Old May 10, 2007 | 12:24 PM
Beeler422's Avatar
Yes, that's fine.
Old May 10, 2007 | 09:39 PM
Mike@ZMS's Avatar
well, I see the yellow and green wire behind the headlight/dimmer switch, but I dont see any "tan" wires... are both wires on the main headlight switch assembly harness?
edit: Nevermind.. I found the wires, right smack under the steering column. Wired it up, it works GREAT... Only problem I have now is that I want to spend another $300 on a second HID set for the Hi-Beam side now... Silverstars look like poop compared to the HID's.
Old May 18, 2007 | 12:21 AM
Kage's Avatar
Cool
Is going to work the same with HID's?
Don't want to **** my **** up.
Old May 18, 2007 | 07:09 AM
If you didn't need to add a relay for the HIDs in the first place then you don't need one with this mod. If you did add a relay then this mod will still use the relay you already installed.
BTW, would it really be that difficult for you to ask questions or post comments without the "colorful" language?
Old May 18, 2007 | 07:49 AM
Kage's Avatar
Cool
Otay i sorry, do i get a time out now or a ?
