Hesitation after LS1-Edit
I had my Fastchips code replaced with LS1-edit tuning this past weekend. In prep for the tuning, I used the GM top-end cleaner and changed the oil the morning before the tuning.
PCM took the stock code fine. During the initial Ls1-Edit setup, the PCM generated an IAC DTC, but I don't recall which one it was. It hasn't come back.
Drove the car home and everything seems good. Drove it about an hour last night and captured a lot of data. If anyone wants to see it let me know and I'll e-mail it to you, with HP/Tq & AFR graphs. I've been trying to evaluate it using the LS1 Tuning Analysis spreadsheet.
So anyway, today it's bucking at various throttle positions driving around town. What should I be looking at to determine the cause of this? Like I said, everything seemed fine yesterday and last night. I didn't drive it a lot with the A/C on yesterday, but today it's hot.
TIA!
TIA!
Re: Hesitation after LS1-Edit
Seems to be fixed. I threw a P0102. I re-seated the MAF connector and tightened a loose bandclamp to the lid. If nothing else it's under warranty until September.
btw, C&S did put the LT's at slightly negative before they messed with anything else.
