Help asap textralia twin no instructions..
We were hoping to install my text twin today. I got no instructions. Tex emailed me yesterday and said they would send them but they haven't yet and time change is likely messing things up. Anyone can scan or post the major stuff. I would like the flywheel and pressure plate torque specs for sure. Not sure if they are same as stock.doubt it for the pressure plate its pretty different.
Also ok to use red loctite on flywheel and pressure plate bolts as will be taking off the clutch again in spring when install new 408 or 427.
And heard something abouit measuring something..not sure what. I will take the clutch apart carefully and make sure to mark flywheel side and all that if it isn't marked.
So appreciate some help as fast as possible on this.
This again is the tex twin not the oz700.
