installed replacement monsoon and car wont crank
i just replaced my stock monsoon with a newer stock one. i disconnected the battery during the install, but im not getting a loc notice on the radio, it works fine. when i try to start the car, the security light comes on, the light on the dash goes out, and i hear a very faint clicking noise. i know the battery is on the way out, but im hoping this is just the security code. i havent had time to test that but i was hoping you guys had some input.
Originally Posted by landstuhltaylor
i just replaced the stock monsoon with cd with the exact same thing from a 2000 formula. it sounds like it really is just the battery system that is dead then because it gets worse week by week even though it is just sitting.
OK so you replaced the HU ONLY...right? Sorry - when you said "Monsoon" -- I assumed the whole system, or at least partially (including the amp) since the HU is just the normal Delco HU (nothing special about it in the Monsoon system).
EDIT: I see you have a '96???..
yeah, its been getting worse for a few weeks. i only really have time to do anything on weekends, so that is when i notice it. its only sitting now until i get a few remaining parts, and then all the things that are pissing me off about it are getting torn apart.
EDIT: last week i didnt think it was going to start but it did. this week it wont even crank
What remaining parts are you talking about? What are you doing to it/what is pissing you off besides the slow cranking?
It's most likely (obviously) your battery that is on its last leg....from what I understand. --I still feel like I'm very confused reading your posts -- am I missing anything? Is anyone else reading this as confused as I am or has sleep deprivation kicked in?
Originally Posted by koolaid_kid
Normally the clicking is when the starter solenoid operating, but there is not enough current to turn the starter. Sounds like the battery is weak.
after re-reading though that has to be the case -- of course it gets worse week by week if the car is just sitting and the charging system doesn't have a chance to operate... if you knew the batt was on it's way out -- and suddenly this problem.....along with the fact that it gets worse week by week........well, check the batts voltage, and get a new one in there -- it's near the end of May -- your car wants to be driven -- stop letting it sit!
the reason its sitting is im waiting on springs to arrive that will actually give it some kind of clearance. the battery was charged about two weeks ago and it seemed fine, thats why i didnt think that would be it right away. the other things that are pissing me off are swaybar links, overheating (OLD coolant), emissions, and other random quality ****.
More likely though -- you're not telling it accurately.
How long did that battery before that one last? -and did it die quickly suddenly after you messed with something?
