who does a good head porting
Ive had severe search problems. But I want to get my heads ported and I wanted peoples opinions and just a list of a few that i could check out...
I checked out Elliots, ETP, and Trick flow... but are there others?
does anyone have first hand experiece or just infor in general
thanks in advance.
thanks in advance.
There are too many to list really. Some go with the most popular, some go with the most expensive and some go with the cheapest. The main thing is to do what your doing now(getting opinions) and then going from that on whats important to you: price, flow, port size, valve size and brand/type, type of casting, type/brand of springs and size of chambers for desired compression ratio.
what type of heads??? are they the stock ones?? if so port work the is good is expensive. for a little bit more money you can get a set of new heads that will run a lot better than stock ported ones
Originally Posted by chromeplated500
853s... from what ive heard a good ported set of these can flow with the best of them..
