ETP...11 degree L92 castings (small bore)
Cary and gang,
What's the latest on these badass heads? You guys seemed pretty confident that they would be out for this season of racing, but this season is already in full swing.
Are these heads going to be a reality anytime soon or should I look for other heads? I only ask because your stuff is badass and am looking forward to running these L92 castings from you guys.
Thanks guys,
Marty
Thanks guys,
Marty
Collections Hold
l92
Marty
That is ironic that you posted that today, I am acually at the shop finializing that part right now. Just happened to stroll on here and see this. I will not post any final numbers until I flow one off the cnc at completion, But I can tell you that with a 2.055 intake valve we hit 348 cfm on the first shot with a 3.900 bore. It flowed all the way up to .700 lift without backing up a bit. I have castings in house that i made especially for this project, so there will be a few sets avalible immediately after we run them on the dyno. There will be two different configurations, one for the 346 based engines and one for the big boys with a larger valve package. I will keep you informed. To post an exact date would only be misleading, but I am confident with our findings.
Originally Posted by cary et performance
Marty
These results are kickass though man. Thanks for sharing. Could we expect these heads to be available by September?
Thanks,
Marty
Collections Hold
They will be avalible in July. It is not an entirely new casting, just a revised version to our current heads, They will be priced in a similar range to our 245/255 heads.
They will be fully cnc ported like all of our heads.
Jason whats up man?
I left you a message about rebuilding that 346 for me yesterday did you get it?
I am also gonna guess that even the small bore L92 head is gonna be 235+. If it gets smaller then that then I will be surprised.
IMO these heads are gonna be in desperate need of a LSX style L76 manifold.
Hopefully someone will make one shortly.
Originally Posted by MPHmotorsports
Jason whats up man?
Marty
Originally Posted by Anonymous
What intakes will work with this 11* L92 small bore head?
Then you have your carb style manifolds.
OWN3D BY MY PROF!
Originally Posted by Beaflag VonRathburg
How is the pricing going to be on the as cast l92 style heads. The big advantage to those is the price / hp. Can you be competitive?
We will be competitive
Originally Posted by http://www.etheads.com/mainpage.htm
Jobber Price: $2,500.00 · Retail Price $2,650.00
Jobber Price: $2,600.00 · Retail Price $2,750.00
GM L92 Fully Assembled Cylinder Head
http://www.sdparts.com/product/12582...inderHead.aspx
Part Number: 12582713
Price: $399.25 x 2 = $798.5
$2650 - $798.5 = $1851.5 more
$2750 - $798.5 = $1951.5 more
How is that competitive?
Collections Hold
competitive
https://ls1tech.com/forums/showpost....9&postcount=82
ET 240cc heads
ET 255cc heads
ET 240cc heads
ET 255cc heads
By high rpm, how high do you mean? When is dyno testing going to be done?
Marty
Collections Hold
rpm
Originally Posted by Mr.MartyStone
Ditto. I'm only looking to spin my pig to around 7500-7600 if it is still making power. How high are you intending for these heads to be spun to on stock cube solid roller setup (will have to be wet sump w/ accusump so can't spin too high)?
Marty
Marty
I was speaking of 7000-7300 range, I would hope the L76 style manifold would carry up there. I'm not looking in the unrealistic ranges. It would not fit the market that most of you guys are in. 500 street cars to 1 all out race car. We will have two different port volumes with the 3.9 bore L92 style head, so if someone wants to build a higher RPM combo (7500 +) They will be able to use the larger cylinder head. I am a firm believer that you do not need a large bore to make all the power you need out of these engines. They dont look as good on the flow bench, but the small bores do make great power, We have not yet seen the limits. That was our purpose to release this part.
cary
cary
cary
Are you looking to make peak power around 7000 and have it carry a few hundred more rpms? I am sorry for the questions I just had a hard time understanding your true intention for these heads.
Also what will the two different port volumes be for these heads, will they use the stock L92 rocker configuration, and what will freedrop come in at for these heads?
Thanks,
Marty
As of know the only plastic that will work will be the L76/L92 manifold as far as I know.
I thought only the LS7 heads were 11*?
So I was thinking that these ETP heads were an L92 design, but on 11* to enhance flow?
So which heads are which?
BTW what is the Deck Thickness on the ETP L92's vs the stock OEM L92 heads?
I have a H&C car, but shoot a little N2O now and then.
I am looking to upgrade my heads.
