people with multiple nozzles on their methonal setups
Old 06-01-2007, 12:40 PM
Boostaholic's Avatar
Default people with multiple nozzles on their methonal setups
I want to run two nozzles on my meth setup
When I ordered the Snow Performance Stage 2 gas kit it was back ordered 2 weeks, but stage 1 kits were in stock so I picked up a stage 1 kit as well
will there be any problems running both kits in parallel?
I'm thinking of having the stage 2 kit come on first because it has a progressive controller then get a 10psi switch and fire the second kit around there, maybe even 15psi for the second kit
Old 06-01-2007, 11:15 PM
Lythropus's Avatar
this isn't related to your thread but what's your set-up going to be when it's all done, i've seen some nitrous post you've done also or was that for a different car?
Old 06-02-2007, 03:32 AM
same car, not sure if we will need n2o or not yet, the plan was to shoot a small shot while we were WOT but not full boost then turn it off.
Old 06-02-2007, 09:30 AM
Grr
Grr's Avatar
you can do as you described. But having to mount 2 kits would be a hassle. the pumps on most meth kits have more than enough flow to support 2, or even 3 nozzles. What you can do for your 2nd nozzle if you like is use a nitrous fuel solenoid on a hobbs switch, just tee into it. or just tee into the one line for the 2nd nozzle. you would be spraying an insane amount of meth with 2 pumps running. Im assuming you are going to run dual M10 nozzles? if so just step up to one M15, or dual M15s, the pump should keep up.
Gary
Old 06-02-2007, 09:46 AM
MIGHTYMOUSE's Avatar
just put a second nozzle in on top of the first kit you bought. long as you dont turn it on at like 0-2psi you wont really have a bogging problem
Old 06-02-2007, 11:01 AM
engineermike's Avatar
True that. With 2 kits, there's an awful lot that can go wrong.
Mike
