How To Replace Front Turn Signal Bulb
i usualy get under neith the car, unscrew a few screws that are on that side, reach my hand up twist out the part the bulb plugs into and plug a new one in, twist it back in, screw the screws back and ur done 10 mintes max
Originally Posted by 1WICKDZ
If its a camaro I just unscrewed the 1 bolt that held the headlight there and it was REALLY easy after I removed the headlight.
Yeah, its a 02 camaro.
Thanks, I'll try ya'lls suggestions.
I hate to pop your bubble dude but obviously you've never removed the passenger side headlight assy on a 2002 Z/28.
Need Pics
Originally Posted by blackztwty8
do what i told u go from underneith that way you don't have to mess with ur head lamp
Could you take a pic of the trap door please?
Thanks
You don't need pics, just look under your front end. You will see a closed flap that has two screws attached to it, unscrew and the flap falls out. Within 5min. you can change both turn signal bulbs.
I have never heard of taking out your headlights to change the turn signals, that is insane!!!!
