Thoughts on msd coil packs.
Old 06-02-2007, 11:08 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default Thoughts on msd coil packs.
If you were changing out your coils would you go with the msd or the truck coils.Were talking new not bone yard stuff that you don't no how much time has on them.BTW this is for hi horsepower app only.
Old 06-03-2007, 12:26 AM
gametech's Avatar
I have MSD coils on my gto strictly as an appearance mod. They make NO difference in power or driveability, they just look nice. BTW, the stock truck coils on my whipple blown silverado are still fine at 240k miles.
Old 06-03-2007, 01:08 AM
ZL1Killa's Avatar
i'm of the same opinion.
Old 06-03-2007, 01:14 AM
Justin00SS's Avatar
I'm not sure if anyone has maxed out the stock coils yet.
I was under the impression that the 1200 turbo 427 LS1 that w2w did was using stock coils of the truck coils.
Old 06-03-2007, 07:31 AM
Rob
Rob's Avatar
Buddy of mine had them on his GTO. Don't think they made any more power at WOT but they did make the idle smoother.
Old 06-03-2007, 08:05 AM
tuff's Avatar
The deal is i can get a set of msd coils for dam near the same money as the truck coils.I just wanna make sure there is no problems with them.
Old 06-03-2007, 11:45 AM
Justin00SS's Avatar
Well if thats the case then ****** them bitches up.
Nobody can argue that they are def better then the stock ones. Its just that the stockers are so good there really isn't a reason to change them.
Old 06-03-2007, 11:46 AM
qqwqeqwrqwqtq's Avatar
I had the MSD coils fail on the dyno on a supercharged LS1. Halfway through a run power dropped straight down about 80 horsepower and the car started misfiring. (this was after a few full pulls were made and the car was running great). After a cool down I made another run and the exact same thing happened, dropping about 80hp in the middle of the run. My only other experience with those coils was a stock car that came in with a misfire problem and the coils were leaking all over the engine, so I decided to swap on a set of truck coils.
With the truck coils on and no other changes the car made a clean pass and their was no longer the 80hp drop in the middle of the run, but damage was allready done as the car was burning coolant out of the exhaust.
The car came to our shop with those coils but from now on I will not tune any LS1 cars with the MSD coils. I don't know exactly what was happening when they failed but the engine showed major detonation upon teardown and had blown headgaskets and a cracked block.
Old 06-03-2007, 11:52 AM
Justin00SS's Avatar
Yeah I've heard of them failing. I think it was just that one or two batches and its been fixed from what I can gather.
Old 06-03-2007, 12:09 PM
tuff's Avatar
How long ago did they have a problem and how big of a batch was bad.My luck ill get a set of bad ones.
Old 06-03-2007, 01:17 PM
Justin00SS's Avatar
Maybe thats why they are cheap. They are usually ~$90 a pop and thats why nobody buys them. They get the truck coils which are just as good and paint them red or whatever color they want.
