hooking sat radio up to stock head unit?
Is it possible to get a direct connection into the stock head unit from a sat radio unit? I've got a sirius starmate 4 and i want to put it in my car but the radio crossover signal blows when you try to listen to it that way.
Copy & Paste Moderator
Check out my XM Satellite Radio setup:
http://www.fadingarrow.com/XMSatelliteRadio.htm
I used a GM9-AUX to convert the CD-Changer port to RCA AUX-IN. It will only work with 1998-2002 Cassette headunit, or 2000 - 2002 CD headunit (some late 99 CD headunits will work with it too). Basically, if the headunit is capable of controlling the factory CD-Changer, then it will work with the GM9-AUX.
