I want this shift knob...BUT....
I want this shift ****...BUT....
check it out:
http://store.summitracing.com/partde...5&autoview=sku
I want this for use with my line lock....
However, dunno if they make it to fit our threads (2002 SS stock Hurst Stick)
16mm x 1.50 I believe...
Does anyone know if this will work? I know it says universal, but that is a load of crap, I bought a Hurst universal t handle once, it didnt fit of course and the adaptors looked like they were for some imports!
HELP!
HELP!
yea i know what you are saying.. i had the same problem with one of my hurst t handles.. just drill out the hole, and get a ... wtf is it called.. die maybe?? the thing that makes threads.. that is what i did.. and it worked fine.
wow that must have been a HUGE tap.....****.....how do you drill the ball out?? isnt a threaded sleeve pressed into the ball?? I dont see how you could just drill that out..I mean I have used a tap and **** before on other parts..but this seems like a lot of work you know!
I will figure it out..I was just wondering if anyone was using this ****!
How bout getting a new shifter stick with the right threads on it??
Erik
Erik
It says the threads are 7/16 20, so, just find out what threads your stick is and go from there. I don't remember off the top of my head. If for some reason the stick is larger, you can drill the **** out and re-tap it. It's plastic according to the link, so that would be a breeze.
hmmm....well the **** is hard epoxy/plastic, but the threads in the **** are not..they would strip im pretty sure if they were...that's what was confusing me, I am pretty sure the **** is plastic, BUT has that threaded metal sleeve in it..
you guys do have a point about tapping though...HMMMM
take your shifter to your local machine shop and have them thread it what ever size you want, we do that stuff for people all the time at our shop, i agreee with ya on the **** most of them do have a steel sleave pressed in to the **** that is threaded
cool man, I may just have to do that...do they retain the metal sleeve? or tap directly into the plastic?
I wouldnt think the plastic would be that strong that's all...thank you for the input!
Hurst makes another **** just like that with the button but it's white and has the 6-speed pattern on it.
Either way the thread size is M16x1.5mm.
Or, you could get a piece of threaded rod (all thread) with the correct threads for the **** you want and then cut the threaded end off of your shifter and weld the piece of threaded rod on and cut it to the length you want.
Shirley Temple Drinker
The hurst six speed **** I bought was different threads, but the threads in the ball were brass, and my LSS ( shifter stick ) is steel so I just forced the **** on ( cross threaded ) to the stick, and the stick which was made of a stronger metal, cut new threads in the ball, its worked perfect for over a year, and I've taken it on and off so many times, its countless.
My Hurst T-Handle **** came with 10 or so inserts for the **** to adapt to the stick, but teh camaro and firebird's shifter stick is the size of the ****, so none are needed, It also came with 10 or so jam nuts which help align the t.
wow that is it!!
****....i need that black one though
