LT installation question
hey guys i just got some LTs and an ORy for my car. its a 98 ws6. I live in New york, and i have my inspectors liscense so visual/sniffer testing i will not have to deal with. Only obd II. I just inspected the car yesterday so im good for a year until i know what to do with the SES light. Anyway for my question...the headers i got are jet hot lt's, but im not sure for what year. They have the two o2 bungs, and on the passenger side header there is 1 bung on the first primary, and 1 bung on the 2nd primary on the drivers side header. Will these work with my 98 emissions systems? And if not, what types of adapters and stuff will i need to delete the emissions systems.
*note i read the sticky, but confused myself ha.
Also, i need the two, 3 bolt gaskets for the collectors/ypipe...are these something i can get through a parts store, or am i going to need to order them.
Thanks
Thanks
On the 98-00 headers with AIR and EGR there should be 2 bungs on the passenger side header, 1 for the AIR and 1 for the EGR. I think you may have the 01-02 headers with AIR only, no EGR. If so this may be a good time to upgrade to an LS6 intake and remove the EGR system.
Originally Posted by Tainted
id say jsut ditch your emissions stuff and have it all tuned out and not worry with it
Originally Posted by delsold
i would do this, but what is required to remove the egr/air systems? What block offs/plates, etc do i need?
I personally see no reason not to hook them up as they help the cats light up quicker-if you don't have them, then just get block off plates.
Far as the 3 bolt header collector gaskets-you can get them from any store-but get the aluminum ones-they won't burn out like the paper and then you won't have to go down there in the middle of winter if your unlucky to change them.
