best combination of cams & heads
Old 06-06-2007, 10:34 PM
trenz_em's Avatar
Default best combination of cams & heads
Heads and cams are like peas and carrots. They belong together, should be bought together, they rely on each other.
so wut u guys think is the best combination ? thanx ..appreciated.
Old 06-06-2007, 10:45 PM
BriancWS6's Avatar
Goals?
Old 06-06-2007, 10:50 PM
PaulC's Avatar
I dont think you understood what the sticky was saying
Old 06-06-2007, 10:55 PM
trenz_em's Avatar
i think thats why i am asking ?
Old 06-06-2007, 11:30 PM
N2OGTO's Avatar
i'd make sure to buy 4 cams for your LS1...
Old 06-07-2007, 12:17 AM
slow1999blackz28's Avatar
yeah man those DOHC LS1s outperform every pushrod ls ive ever seen theyr amazing
Old 06-07-2007, 01:01 AM
FieroZ34's Avatar
I'll put it plain and simple.
Buy the biggest cam you can find.
Then go buy the heads with the biggest flow numbers at lifts you'll be using.
Old 06-07-2007, 02:21 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
I you plan on a lot drag racing and you have a big stall auto, the unequivocally yes.
However that may not be the best course of action, and you could lose to smaller cammed cars on the street. What transmission do you have? What type of driving, and more importantly racing, do you mostly do? What other mods are on the car? Headers? Exhaust? Intake? What else do you plan on doing to the car? What rear-end ratio?
More details = much better advice on a head/cam combo.
Old 06-07-2007, 02:46 PM
Daredevil_TA's Avatar
Somehow, I don't think you read the whole sticky, if you did you wouldn't be asking this question, and you definitely wouldnt be saying camS
Old 06-07-2007, 03:31 PM
rk_2000_Z/28's Avatar
You need to figure out what kind of performance you are looking for and what the application will be and go from there.
A lot of the sponsers on this site sell complete packages that take the guess work out of it!
Texas Speed & Performance (TSP) would be a good place to start. They really know their stuff!
Old 06-07-2007, 03:51 PM
shudog's Avatar
what he said... call a sponsor like TSP or Thunder Racing and tell them what you're looking for. Then use that as a starting point and research... nothing worse than spending $2K and wishing you'd gone a different route with the heads/cam. The cam in the sig above is a great all around cam and if combined with a decent set of heads should get you all the power you'd ever need.
Old 06-07-2007, 04:46 PM
Smoke Panther's Avatar
which is exactly what the OP didn't do, hence why FieroZ34 gave him a sarcastic response.
Old 06-07-2007, 06:35 PM
FieroZ34's Avatar
I'm not even sure if I was being sarcastic, but if so then I might as well stand behind it *shrugs*
Old 06-07-2007, 08:53 PM
BlueSix's Avatar
You should do your research and decide what your ultimate goal is. Then you should pick the set of heads to accomplish this goal. After having the heads flowed you should send those specs to a custom cam grinder and tell them what your goal is. That will give you your best personal combination of heads and cam.
Old 06-08-2007, 06:45 AM
777's Avatar
pick your cam from your heads, most people do it the other way around
