Why does my brake pedal go soft after hard cornering?
Old 06-08-2007, 12:01 PM
BAD LUK's Avatar
Default Why does my brake pedal go soft after hard cornering?
After I take a corner hard, the first time I hit the brakes the pedal goes down a lot further than normal.
Checked my fluid level and its slightly below the max mark. Not sure what else it could be. WTF??
Old 06-08-2007, 01:54 PM
daryl2cb@yahoo.com's Avatar
bleed the system, first did you notice your abs light, or the traction light coming on?
Old 06-08-2007, 08:33 PM
mitchntx's Avatar
There is a phenomenon called "knock back".
It's basically the lateral play in the rear axles that shift out or in a very small amount. As the axle moves, it shifts the rear brake pad in, compressing the piston. Common occurrence with well worn rear brake pads.
A similar thing can occur if the front wheel bearings are really loose.
Old 06-11-2007, 09:21 AM
NOBR8KSS's Avatar
Happens to me all the time...you eventually get used to it and learn to tap the brake pedal to reset the pads.
Old 06-12-2007, 07:45 AM
BAD LUK's Avatar
The brakes are worn, and I guess so is the rear end if there is play in it. Since the fluid is the original, I should probably do a change also ( I know better, but just keep putting it off).
Thanks for the help.
Old 06-12-2007, 09:39 AM
mitchntx's Avatar
Let us know the results ... everything is just a guess.
Old 06-12-2007, 12:58 PM
hpjunky98's Avatar
I experience the same thing but its only after a powerslide. I replaced the rotors, pads, blead the system and got steel braided lines and it still does the same thing. I really doubt there is any play in the rear as Ive got the rear suspension covered. might check my wheel bearings now tho...
Quick Reply: Why does my brake pedal go soft after hard cornering?
