Why does my brake pedal go soft after hard cornering?
After I take a corner hard, the first time I hit the brakes the pedal goes down a lot further than normal.
Checked my fluid level and its slightly below the max mark. Not sure what else it could be. WTF??
There is a phenomenon called "knock back".
It's basically the lateral play in the rear axles that shift out or in a very small amount. As the axle moves, it shifts the rear brake pad in, compressing the piston. Common occurrence with well worn rear brake pads.
A similar thing can occur if the front wheel bearings are really loose.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Happens to me all the time...you eventually get used to it and learn to tap the brake pedal to reset the pads.
The brakes are worn, and I guess so is the rear end if there is play in it. Since the fluid is the original, I should probably do a change also ( I know better, but just keep putting it off).
Thanks for the help.
I experience the same thing but its only after a powerslide. I replaced the rotors, pads, blead the system and got steel braided lines and it still does the same thing. I really doubt there is any play in the rear as Ive got the rear suspension covered. might check my wheel bearings now tho...
