Urgent - rebuilding mcleod master question
Old 06-11-2007, 05:42 PM
Viper's Avatar
Default Urgent - rebuilding mcleod master question
The spring did a jack in the box when it popped out when taking it apart, and I don't know which direction the black cupped seal at the end goes.
Is it flat part against the spring bottom or does the spring sit in the cupped portion? It doesn't fit in the cupped portion when sitting outside the bore so that's why I'm asking, but flat part up against the spring doesn't make sense either.
I've searched for 2 hours and no one ever aksed this.
Thanks!
Old 06-11-2007, 07:29 PM
Viper's Avatar
Got it for future reference and searches:
Put the M/C on end with the rod facing up. Put the spring in first with the metal cup attached facing upward. Then put the rubber cup in next with the hollow side downward. Then put the piston on top of the rubber cup (flatend down) and then the pushrod with washer and snap ring last. Lastly the rubber boot.
