mounting PCM in a fox
i was being a bit lazy and tired of dealing with wires but i finally mounted my PCM. i wanted it inside the car for cleanliness under the hood so i put it above the blower motor. i had to remove the 'outside air' part of the blower motor case so the ac will only suck air from inside the car (which i always have it on max anyway) but it was the only way i could find enough space and harness slack for it to work. i hope this helps.
and it will be at the track next saturday, hopefully on spray
