plastic slave cylinder disconnect tool
Old 06-16-2007, 08:59 PM
Furious_George's Avatar
Default plastic slave cylinder disconnect tool
last time i had to remove my transmission, there was no plastic slide inside the quick disconnect on the slave cylinder. had to actually use a hack saw and that sucked pretty bad. i really don't want to do that again next time i pull the tranny (that sounds disgusting). i was wondering if anybody out there has a spare or knows how to obtain one besides purchasing a master cylinder with the attached line.
Old 06-16-2007, 10:57 PM
wrencher
wrencher's Avatar
I have used brake caliper plastic hardware. you can find them at a parts store. Usually motor-mite or dorman makes them.
You can ask if they have a pisture guide to the brake hardware & pic it out. I dont remember the #.
Either that or go to a hardware store & get something plaste that you can slide in there to release the lock.
Old 06-18-2007, 02:52 PM
Dal1as's Avatar
Here you go. Had to deal with the same problem.
https://ls1tech.com/forums/showthrea...9&page=2&pp=20
Old 06-19-2007, 12:16 AM
thank you sooo much, this will help out! i think they changed the part # because i couldn't find it. anywho, that's one of my many new quests.
Quick Reply: plastic slave cylinder disconnect tool
