Necessary Machine Work?
Old 06-17-2007, 10:32 AM
striker754's Avatar
Default Necessary Machine Work?
I am building a turbo ls1, going to use the stock crank, probably scat h beams and mahle forged pistons. I am staying stock displacement. I will be putting the motor together with a friend who is good at putting them together. Anything to watch for that is different on an LS1 than a regular sbc?
I am building off of a longblock 00 ls1 that came out of a wrecked car so its engine should have no problems like spun bearings.
What is absolutely necessary when building a new motor? I will have them check the heads for flatness and balance the rotating assembly. What else? Trying to not spend money on "extras" that I really don't need.
Thanks guys.
Old 06-17-2007, 12:27 PM
stealth71's Avatar
I've been told the cylinders need a hone with new rings.
Old 06-17-2007, 04:28 PM
striker754's Avatar
did some searching and looks like maybe just honing the cylinders and the mains is all I would need
