Help find the missing RWHP : 408ci, M6, 9"
here is the graph....each time hp went up. a few things to note. the car is a full bolt on car, Fast 90/90, 30# Fast injectors, 257/266, .622/.642, 113 lsa cam, PRC stage 3 heads, ASP pulley. Headers are Grotyohan 1-3/4" Long tubes, 3" into a Hooker Aerochamber. he dual cutouts are in the y pipe.
Motor has about 1000 miles on it, also with a new 9" installed at the same time. Fuel pressure is fine as the AFR is pretty dead on, and last run i believe had 28* of timing. I am throwing a code or 2, 1 being a misfire that i believe to be my drivers side o2(awaiting my extension to install new o2), and egr code, and maybe a TPS code(p0121).
im thinking theres more there with more of a break in and some more tuning(something broke so we had to quit for the night), my tire pressure was pretty damn low, weather was about 88*, ~56% humidity, and ~30.07 barometric pressure(i think)
help....
help....
What psi are those fast injectors rated at?
Were the dyno pulls done with the cutouts open?
That's a big *** cam on a 113 so it's going to want rpm but your peak is fairly early. I'd like to see a graph of the manifold pressure to see if you're pulling vacuum up top.
If there's a tps code are they sure the tps is reporting 100% at WOT.
When you say you quit early because something broke, did something break on the car or on the dyno?
LS1 Tech Administrator
Moved from Advanced Tech section. More eyes in here.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
the lower pull was through the exhaust(453rw) the higher number was cutouts open(481rw).
TSP mentioned it should peak around 6400, my rev limiter's at 6700.
hmmm does WinPeP 7 have a map overlay? i havent used it that much.
That TPS @ %100 comment makes sense, ill have to ask the tuner...
and nothing broke on the car, the handheld xcalibrator that loads the tune overheated when someone was messing with the battery, so it wouldnt read anymore, we just couldnt tune anymore.
i also posted this thread in the dyno section to get some more views...
https://ls1tech.com/forums/dynamometer-results-comparisons/734387-help-find-missing-rwhp-408ci-m6-moser-9-a.html
and Patrick G, thanks...i appreciate it.
