Is my shock nut loose, or what?
Old 06-19-2007, 07:24 AM
Wilkenstein's Avatar
Default Is my shock nut loose, or what?
I get a slight rattling noise from the front passenger side suspension (I think). It only happens at low speeds on bumpy roads, going over speed bumps, breaking, and low speed left turns. Tie rods and ball joints are good according to the wheel wiggle check.
Car is also rather unstable at high speed. If it's still making noise I can't hear it over the exhaust at speed. I had the alignment checked and all is good there.
Any ideas or anyone experience the same?
Old 06-19-2007, 11:08 AM
colby72olds's Avatar
is your car lowered? because i lowered my t/a about a week ago and it started doing the same thing. when i got my front end aligned, the shop said they didnt know what it was.....i am just kind of worried that something bad may result from this
Old 06-19-2007, 08:55 PM
bone stock suspension with 50k miles or so.
Old 06-20-2007, 11:21 AM
any ideas?
Old 06-20-2007, 11:36 AM
tbird31's Avatar
wheel bearing?
is it a poping/knocking or just a rattle?
rattle=pop the hood check the shock tower bolts. if that doesn't help. take off the wheel and make sure everything is tight
pop/knocking=lower aarm bushings going bad. that's what's happened to my car now. everytime i hit a bump/divit/anything it pops like a SOB...
Old 06-20-2007, 04:02 PM
jchrisos's Avatar
Have you checked your swaybar endlinks?
Old 06-21-2007, 03:27 PM
ae13291's Avatar
it could be your ball joints or check to see if it is your bushings on the sway bars or bolt on the a arm may be looose
Old 07-07-2007, 05:39 PM
Vinny1's Avatar
I'm reviving this thread because I am experiencing the same thing. My car is a BONE STOCK 02 WS6 Trans am with 38,xxx miles. When driving slowly though my neighborhood I hear and very faintly feel a slight hollow knocking on the driver side. I have checked the tightness of most of the bolts and was almost prepared to purchace new struts for the front until I ran into this thread. I read elsewhere that I need to check the lower control arm bolt because they loosen up. Is there anything else that could be the problem? I may be wrong but I imagine this is a problem for lots of others
Vinny
Old 07-07-2007, 11:22 PM
1BADAIR's Avatar
its common for the sleeve in the upper strut mount to break loose
