Which rotors for a C5 conversion?
Old Jul 5, 2007 | 07:58 PM
DirtyBird222's Avatar
Default Which rotors for a C5 conversion?
Which rotors should I get for a C5 brake conversion? I work at a dealership so I got the calipers for pretty damn cheap. Going to order the brackets and all that crap from kore3, I just need to find a good set of drilled and slotted rotors that can take some abuse from autoxing and track days.
Old Jul 5, 2007 | 09:14 PM
DuronClocker's Avatar
Going with drilled for looks I imagine?
I went with the Autozone blanks (not drilled/slotted) for $85/pair or what-not.
Old Jul 6, 2007 | 09:01 AM
lo_jack's Avatar
I would not autox on a drilled slotted rotor...but I am no scientist.
I would get some brembo blanks or at least some autozone blanks. I think those are duralasts and IIRC they are pretty good. I used them a couple of times without issue, but I also wasn't racing on them.
Old Jul 7, 2007 | 05:10 PM
to the top
Old Jul 7, 2007 | 05:17 PM
purdueranger's Avatar
NAPA Rotor
This is what I run, this is for the front Left though.
Old Jul 7, 2007 | 05:23 PM
GR33N GoblinM6's Avatar
i went with autozone Duralast's.. stock OE replacements..
Old Jul 7, 2007 | 08:19 PM
greendrazil's Avatar
Why would you not use slot/drilled for autox? Would they not help with heat reduction?
Old Jul 7, 2007 | 10:49 PM
VIP1's Avatar
Copy & Paste Moderator
Nope. They dissipate heat worse and are prone to cracking.
Check out this sticky:
https://ls1tech.com/forums/showpost....91&postcount=5
Old Jul 7, 2007 | 11:11 PM
subtlez28's Avatar
Drilled/Slotted are only for looks...don't believe the hype on any perf gain. Not to mention they will EAT pads.
I'll PM you a source.
Old Jul 8, 2007 | 12:11 AM
Proud2bSS's Avatar
http://www.rotorsonline.com/ = they are a sponsor.
