question about cam sound and idle
Old 06-21-2007, 03:52 PM
hnaskoct's Avatar
Default question about cam sound and idle
i wanna know is it possible to get a cam made that idles identical to a stock ls1 cam and sunds like one ..because im not into the choppyness but i wanna produce some more power and im tryin to find out if i was to crank up my car what it sit and pur like a kittin nice and quiet!! some one help plz!!!!!!!!!!!
Old 06-21-2007, 03:53 PM
ICRAZY6's Avatar
There are plenty of Cheater cams out there. Check out TSP they make a great one. Sounds and idle like stock but produces tons of power.
Old 06-22-2007, 02:54 PM
hnaskoct's Avatar
BUMP bump
Old 06-22-2007, 03:14 PM
bczee's Avatar
Look into cam with a larger LSA 114-116 deg.. that will help bleed off some of that choppy idle.
Give the cam manufactors tech line a call or email them.. they will recommend you something from there line of cams will suit your requirements.
Old 06-22-2007, 06:12 PM
CamaroSS's Avatar
Thunder Racing Custom Camshaft
"CheaTR" - 214/230 .601/.575 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
Hope this helps....
