Rack and Pinion. ?high pressure side?
which side is the high pressure side. on a C4 rack and pinion.
I'm guessing its the smaller diameter connection.
Before I have my hoses made I would like to just double check.
This is a 1990 rack and pinion steering running off the 2004 GTO power steering pump.
Thanks
The return side I was just going to make a bubble fitting and then use rubber hose.?.?
Thanks
Can anyone with a C4 look and tell me if the upper smaller diameter fitting on there rack and pinion goes to the high pressure side of the power steering pump?
