Fuel pressure issue
Anyone got any ideas? This seems like a fuel system issue but maybe someone out there has another idea.
Thanks!
this should be just a test to see what static pressure your getting. That should test your system. If it maintanes a steady pressure, then you know it is something else. PCM to the Relay wire, fuse holder, ground (90% of electrical problems are related to bad grounds)?
As far as a leak goes I didnt think about an injector. I wouldnt think with the pullout only having less than 10 miles on it when I installed it that it would be an injector, but anything is possible. Second pump in the car is new along with the FPR so an injector is about all that is left to check.
