LS series iron block???
Old 06-26-2007, 05:38 AM
Big_Z_racing's Avatar
Default LS series iron block???
I am going to put an LS series motor in my LT1 Camaro and i'm trying to find the best deal out there. I'm looking for a stroker shortblock and then build on that...which brings me to a question. If i were to buy an iron block vice the aluminum, which could take some more abuse...say from long road racing runs, would all the typical LS series parts fit on it? i.e., FAST intake, heads, fuel, tune. or am i going to have to start buying these LQ parts and completely rethink the build?? I'm new to building LS motors so any help would be appreciated!
Old 06-26-2007, 06:54 AM
daniel6718's Avatar
yes...but if your not going to be making over 700hp id go aluminum...more than a 250 shot or high boost youll need to consider iron otherwise save some weight and help handeling
Old 06-26-2007, 07:16 AM
hosspowerinc's Avatar
I agree. The aluminum blocks hold a lot of power. HOWEVER, I do have a 6.0 for sale for cheap if your interested.
Old 06-26-2007, 08:02 AM
makes sense on the horsepower and weight issue. i'm not planning on making that much power, just always hear the bigger the stroke the less reliable a motor becomes. i'd be curious on the details and what your asking Hoss, send me a message about the info.
Old 06-26-2007, 08:24 AM
SheldonZ28's Avatar
Iron blocks are not as heavy as everyone claims. Their an extra 60lbs or so over the aluminum.
The iroc blocks are great because you can get them for cheap.
To answer your question in regards to transferring things over, is YES.
However, you cannot do single things, such as an intake. If you decide to use an LS intake, you need LSx fuel rails, and injectors. Heads are interchangable etc. Cranks are the same, rods the same, pistons will be different due to a different bore.
One good thing about iron is, say your engine decides to cough up a rod. Aluminum blocks will generally have the rod hanging out the side of their castings pretty quick. Iron blocks are somewhat stronger in that sence, and the block may be repairable with a bore.
Keep in mind however, that you will want LS F-body serpentine setup, and oil pan.
5.3 Engine's can be had in yards for $500. 300hp, that includes everything.
Sheldon
Old 06-26-2007, 08:39 AM
the_merv's Avatar
LS1Tech 10 Year
Here is some info for you on how to convert it over..
https://ls1tech.com/forums/conversions-swaps/737310-built-lsx-stroker-into-95-z28.html
How much are you willing to spend?
Old 06-26-2007, 09:53 AM
9540x's Avatar
If you're looking to build a stroker, go with the 6.0 iron. It is a very good choice and people have stroked them all the way to 408cid. The aluminum LS1 can be stroked but it requires resleeving since the cylinder walls are so thin and resleeving's expensive.
Old 06-26-2007, 04:01 PM
ILLINTENT's Avatar
6.0 is the only way to go, you get a bigger 4.0" bore too, which helps with bigger valves and head flow.
Old 06-30-2007, 08:41 PM
SheldonZ28's Avatar
Also means you can run L92 heads + L76 intake for some impressive power, for rediculously cheap price
Old 07-01-2007, 12:14 AM
the_merv's Avatar
LS1Tech 10 Year
This guy is thinkin on the right track...
Quick Reply: LS series iron block???
