painting rear rotor hubs
So I put some smoothie II's on my car, and they look awesome. The only problem is that the rear rotor hubs are much more visible now, and are rusty and ugly. I plan on taking the wheels off, taping off the disks and painting them. My question is, should I attempt to try and clean off the rust or just paint over it..it looks like the entire hub is made of rust, so I dont think scrubbing it would do any good...If I need to clean them, what should I use? Any input would be appreciated.
-J
-J
I used like 40 grit sand paper to start then worked my way up to like 200 I think. You can use a wire brush to loosen up alot of the rust. Or If you got a spare $180 buy the WS6 store rotor set. That is what I have on my car now. I had to respray the inside of the rotors when they started to rust. If I had to do it all over again I would of clearcoated the hubs before I put them on. I used duplicolor silver spray caliper paint and they look great.
