Drivebelt problem
Old 06-27-2007, 09:19 PM
BTTM's Avatar
Default Drivebelt problem
My drivebelt keeps coming off under extremely hard acceleration. Any way to stop this? I replaced the belt recently but each time I floor it to pass someone or whatever the belt comes off. But it only happens under hard acceleration.
Any help is appreciated.
Old 06-28-2007, 01:57 AM
staringback05's Avatar
check the tensioner...and also make sure you dont have any ribs broken on the pulleys or any are warped...etc
Old 06-28-2007, 11:33 AM
waldershrek's Avatar
Yeah this kept happening to me with my third gen until I discovered the power steering pulley was bent which kept shredding belts. Make sure everything is straight and has no sharp edges
Old 06-28-2007, 11:57 AM
tylerdj's Avatar
Check your belt tensioner and make sure that it is holding the belt tight enough. I had that same problem a while back on my Camaro and it turned out to be the tensioner.
Old 06-29-2007, 07:50 PM
BTTM's Avatar
Thanks, I'll check the tensioner and the pulleys this weekend.
Old 06-29-2007, 09:10 PM
ghardester's Avatar
Yeah, the tensioner is probably bent or misaligned. I bent one on a car once, used too much muscle while changing the belt.
