ABS Code 95
ABS Code 95
I have a 95 Z28 a4 that is setting off a code 95 (brake switch circuit open). When this happens I also have no left turn signal. Right turn signal works fine though. All bulbs are good on the left side. Is it possible it could be the turn signal switch or the brake switch itself? Anyone been here before or know what is causing this. Any help at all would be greatly appreciated.
