how do you adjust the headlights one a firebird
they are way low to the ground and i can not see very well at night. the head lights them selfs are all the way up but the beam of light is to low
Copy & Paste Moderator
On the top and side of each headlight bulb is an adjustment screw that uses a T15 torx bit. The shroud is notched and you'll see the adjustment screws through the notches.
