clutch don't work need assistance
A couple months ago, I replaced the slave cylinder. Haven't driven the car much since. Shifting has been getting worse and getting into first or reverse from a stop was getting harder also. I replaced the master, completed the drill mod, DID NOT complete a bench bleed. Installed the master and have been sucking the fluid and air out of the bleeder on the slave. I am now only removing fluid, no air bubbles are comming out of the bleeder, yet, I still can't put the trans into ANY gear while stopped. What is going on?
wrencher
Did this problem before the slave R&R & just crop up out of the blue?
No clutch change etc?
If it is mushy alot of play & engaging at the floor, you likely have air in there then.
Look at the bleeding thread;
https://ls1tech.com/forums/manual-transmission/737930-correct-way-bleed-clutch.html
