is an ls7 clutch ok with stock '06 GTO T-out Bearing???
Old 06-30-2007, 10:57 PM
PRAY HRD's Avatar
Default is an ls7 clutch ok with stock '06 GTO T-out Bearing???
hey guys........
i'm posting this for a friend of mine who needs an answer QUICK! he just swapped a T-56 in place of a th400 and the trans just started pissing fluid.
the combo....
he's got a '68 Camaro with a NEW factory stock '06 GTO T-56 trans that came with the throwout bearing already installed. he was wanting to know if this setup is a match with an ls7 clutch setup or not? fyi, the car is NOT a GTO, it's a 68 Camaro, only the trans is for a GTO.
any help is GREATLY appreciated!!!
-Dave-
Old 07-01-2007, 05:04 PM
PRAY HRD's Avatar
anybody???????????????
Old 07-01-2007, 07:55 PM
Tootall's Avatar
what it bolted to? engine wise?
Old 07-02-2007, 08:41 AM
PRAY HRD's Avatar
6.0L iron block ls based motor.
Old 07-02-2007, 09:45 AM
Tootall's Avatar
with a 6.0 yes it'll work, but what year block is it. The 99-00 and some 01's had the longer crank.
Old 07-02-2007, 04:47 PM
PRAY HRD's Avatar
he's not sure, but he said it had a 3/4" adapter that was removed and so it's the length of the newer cranks now. thanks for helping out with this.
