FS:07' 6.0 Longblock/ 6.0 LQ4/ 4l60e
6.0 bare block with crank 450$ (lq4)
6.0 pistons/rods 75$ (lq4)
6.0 317 heads set with stock valves/springs 250$
2500 07' 6.0 longblock with 100 miles, -2000$-
l92 heads-823 casting
6.0 cast iron block
comes with l76/l92 truck version intake, with dbw tb
no fuel rail, no injectors.
oil pan, and wp., damper, no other front acc. oe elec.
no exhaust manifolds.
also have 18k mile 6.0 lq4 longblock 1400$ -SOLD-
no acc., comes with intake, no tb,or elec.
comes with oil pan, and covers.
00' 4l60e 500$ -SOLD-
located in houston
all quality stuff, ready to work
6.0 cast iron block
located in houston
Originally Posted by 5w20
dont want to be nosey but where do always get these 6.0L blocks?
vehicles, part owner of salavge yard in houston. i get first crank at engines
and stuff, he does not care about hot rod and fbody's and such. my source
i have a day job, but i just cant pass up anything lsx.
Originally Posted by 99Silverado5.3
Year? I am asking because if it is 99 or 00 it will not mate up with the 4l60e.
Thank you,
Dillon
Thank you,
Dillon
itcame with alloy heads, so its 01 and up since
iron heads were only available in 99' 00'
those engines were also equipped with the large flange crank that is .400
thicker at the rear flange to flexplate. and use a thicker cover and rear seal.
not sure on yr. but it is 01+ im sure. it came with alloy heads and reg. crank
flange with reg. rear cover. spacer for flexplate.
do u mean the crank will not work with a 4l60e flexplate? if its a large flange crank it will not work with 60e, due to the .400 thickness of crank.
this crank is a regualr flange. all mounting holes for trans on engines are the same regardless of yr.
