02 sensor replacement / how many?
I've noticed a steady decline in gas mileage (I haven't changed my driving habits or anything like that) recently and I'm looking to replace my O2 sensors. I'm not sure what the best route to take is. I don't have aftermarket headers on the car. From the searches I've done I see there are a few options. One being the Bosch 13111vette rear o2s that have the longer wiring harness for aftermarket headers which I don't have. The 2nd option is the AC Delco original replacement O2 sensors for 1998-2002 LS1 F-Body, Passager Side & Driver Side (Pre & Post Cat). It looks like they come with quantity 2 for passenger side & 2 for drivers side. Does this mean I need to replace a total of four 02 sensors? I'm not sure I'd need the Bosh 02s, I just want to make sure I make the right purchase and get the correct quantity. Any info from someone who's been down this road before would be much appreciated. Also if you've had a good experience buying from a particular place could you let me know as well. Thanks!
I have had to replace my O2 sensors twice because of failure on my 02 ss. I have talked with people that have never had a problem with O2 sensors. I do have long tune Jet Hots and no cats so I guess they get a little more heat. I use the 13111 Bosch as I was told they would take more heat better than stock.
With stock exhaust you should just go with a direct replacement...there's not really a need to use the 13111. There are 4 O2's total...1 before and 1 after the cats on both sides.
Originally Posted by tylerdj
If there's a problem with your O2's it should be throwing a code.
