Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
My parts list, Camaro Z28
Old 07-10-2007, 10:25 PM
CamaroKidZ28's Avatar
Default My parts list, Camaro Z28
Ok, so it's been awhile i have wanted to post this up, this is the parts list on my 1970 1/2 Camaro Z28. ( True Z28 by the way, I have the protecto plate )
Engine / Drivetrain
-the 454cid has become a 491cid stroker-roller motor
-4 bolt main
-Closed Chambered Heads 3872702 ( 1966 Corvette 427 cid )
-Intake edelbrock performer 2.0 with 850 CFM demon carb
-new 4.25 stroke cast steel crankshaft
-Forged H-Beam connecting rods "floated & bushed wrist pins" w/ ARP 7/16 rod bolts
-Keith black Hyperutectic flat top pistons
-cloyes double roller timing chain set
-Melling oil pump
-Crane Roller 1.7 roller rocker arms
-Stainless oversized 1.880 exhaust valves
-stainless oversized 2.190 intake valves
-double valve springs
-chromolly valve spring retainers
-Hardened 7 degree valve keepers
-Heavy duty harmonic balancer
-Heavy duty flex plate
-ARP 7/17 rocker studs
-STD. Main, Rod, and Cam bearings
-12 pt. Intake and Exhaust
-Chrome fuel pump
-Mallory ignition and wires
-Chrome pulleys
-high torque starter
-hd motor mounts
Machine Work
-Bore and hone cylinders 4.290
-Aline hone main journals
-R&R cam bearings
-Machine valve seats to fit oversize valves (multi-angle)
-Pocket port intake and exhaust ports to fit valves
-Intake runner flange
-Magnaflux heads
-surface cylinder head deck
-Machine and install bronze valve guide liners
-Machine for solid teflon valve seals
Transmission
-400 Turbo Transmission from Jasper Transmission. High performance class-3 racing transmission built with all heavy duty hard parts and shift kit.
-New tranny cooler
-Hurst Ratchet shifter being installed July 11th
-Rear gears changed from 4:11 to 3:73
-New richmond rin and pinion set
-Subframe connectors
-Power steering
-Front Power disc brakes
Body
-New front fenders
-New door skins
-New full quarters
-new floor pans and trunk
Paint
-House of Color 3-stage process
-1st silver / white pearl
-2nd Tangerine Kandy
-3rd Clear.
-Fades at the bottom to a deeper apple red kandy
Suspension
-Front suspension was completely rebuilt with new control arm bushings-upper and lower.
-New Ball joints, upper and lower
-New stabilizer links
-new shocks
-brakes
-new front sway bar bushings
-new radiator core support and ushings mount kit
-new 3 core radiator
-rear traction bars
Interior
-Year one covers
-New carper
-New headliner
- Phantom dash guage kit with carbon fiber dash plate
-grant steering wheel
-new dash pad
-new center console
New Parts
-New glass all around
-New front spoiler
-Chrome bumpers in back and front
-Door handles
-Emblems
-Reveal Molding
-Rocker moldings
-Weatherstrips
-Powder coated headers and aluminized 2 1/2'' exhaust with flowmaster mufflers and tips
-New electric fan
-Flex fan
-Chrome alternator
-Dress up chrome kit
-Chrome water pump
Runs on 93 pump gas and I drive this car every day.
So that's the list that i have for this car, comments are of course welcome.. im trying to learn as much as i possibly can. My mechanic and family friend tried to persuade me to install a 100 shot.. Would rather not and upgrade the engine instead
Old 07-11-2007, 03:44 PM
What would you recommend when it comes to mods? What are the weak spots i should upgrade first, etc etc.. also out of curiousity what would be needed to procharge? I read a little about whats needed in the other section but with this engine do i need anything different.. What would be the best performance upgrade?
Quick Reply: My parts list, Camaro Z28
