Australian LS1 And Turbo Scene
Hey how is everyone, just saying hello
and also just curious if you know much about the australian ls1 and turbo scene??
I have a Holden VL Commodore, with an rb30,
with arias forged pistions, scat h beam conrods, extensvie head work, stage 3 cam,
and gt35/40 roller bearing turbo, 1000cc injectors,
Nitrated crank
Race bearings
Gapless rings
N1 GTR high flow oil pump
jatco 3 speed auto, full manual valve body, kevlar bands, biller servos, built to handle 600rwkw, with a 3500RPM Stall
custome plenum, larger throttle body
9inch diff, with 31spline moser axles,
3.9 lsd
car has been dynod achieved 460rwhp@22psi
QUARTERMILE TIME: 10.20@129.68
60foot time of: 1.46
Is there RB30 is places other than australia
Nitrated crank
Race bearings
Gapless rings
3.9 lsd
an rb30et is basically like an rb26 except its single cam, its a 3.0litre, and it was made in 1986-1988 , and is turbocharged using a t-03 as factory hardware
the difference between the N/A was the turbo had low comp, diff pistons, fuel systems etc...head work....
HERE are some stats
<><><><>3.0 EFI Engine specs. <><><><>
Nissan RB30 2962cc
Capacity: 2.960L
Induction: EFI
Valvetrain: Overhead cam, 2 valves / cylinder
Bore x Stroke (mm): 86.0 x 85.0
Compression ratio: 9.0:1
Maximum Power: 114 kW
Maximum Torque: 247 Nm
TOP SPEED: 3.0 litre SL 187 km/h
<><><><>3.0 Turbo EFI specs. <><><><>
Nissan RB30T 2962cc
Capacity: 2.960L
Turbo: Garrett T3 water-cooled
Boost: 7psi non-intercooled
Induction: EFI
Compression ratio: 7.8:1
Maximum Power 150kW@5500rpm
Maximum Torque 296/Nm@3200rpm
6100rpm redline
TOP SPEED: 223 km/h
at the time these were very good power stats for a car in 1986
when compared to the V8 offering in same models the turbo had them beet
4.9 V8
Capacity: 4.983L
Valvetrain: Overhead valve, 2 valves / cylinder
Bore x Stroke (mm): 101.6 x 78.6
Compression ratio: 8.5:1
Maximum Power: 122 kW
Maximum Torque: 323 Nm
The fastest current VL running an rb30ET, runs a 8.38@162.98MPH Quarter mile, with Single Cam as well, no methanol, GT42 spec turbo, 2 speed powerglide, and about 830rwhp,
check out a video
http://www.youtube.com/watch?v=zENPCCRBKTo
and there are many others pulling similar 8second times, and should soon crack the 7second mark
HERE are some stats
Nissan RB30 2962cc
Capacity: 2.960L
Induction: EFI
Nissan RB30T 2962cc
Capacity: 2.960L
Induction: EFI
6100rpm redline
TOP SPEED: 223 km/h
4.9 V8
Capacity: 4.983L
check out a video
