people with sts come take a look
Thanks for you help kyle
Thanks for all your guys help kyle
I've got a M6 with GT67 upgrade and meth, the kit sucks at the track. Lag is a bitch off the line, you can help it by wrapping your exhaust and going with a 2 step or something similar. On auto cars it doesn't seem to be an issue since they can load up the converter on the line giving them some boost off the line.
Best run in the 1/4 was 12.4 at 119mph. Running against a good friend with small cam, headers tune and a 100 shot and he killed me everytime at the strip. I had more power than he did and would start reeling him in but he would get so far ahead off the line that it didn't matter. From a roll it was a different story as I'm sure it would've been different had I had a front mounted setup.
I'll be hitting the 650RWHP mark with my setup (thats the plan anyways
) and I'm doing everything I can to make my kit as efficient as possible. To early to tell if it will work out if it doesn't the APS twin turbos are in my future. Again just my experience. Trending Topics
I have 408ci and with a 585/585 225/225 116LSA patriot heads with 2.08 1.6
with the same engine i didnt made that power with the STS i had the boost to 16 and it only jumpt to 685HP thats it.
wish you good luck my friend.
) and I'm doing everything I can to make my kit as efficient as possible. To early to tell if it will work out if it doesn't the APS twin turbos are in my future. Again just my experience.You can set up the kit to just turn on the juice for 1st gear. Your outcome will be different.
