Spohn 3rd gen mounts
how the hell are these things supposed to sit? im using the one marked with R on the passenger side and no more than 2 bolt holes line up at once.
No offense...but you do know they sit further back than the stock mounts right??? You will only get like 3 bolts in, and the 4th you will have to drill. And I think that was only one side. Also, its not hard to put them in oriented in the wrong direction.
Here is a picture of mine... The notch is the a/c notch in the front of the crossmember. I only remember having to drill one or two holes...the rest bolted right up.
Justin
Justin
the front Kmember SBC mount holes are not used.
one of the rear holes lines up with a previously unused Kmember hole.
because of this, you cannot use the spohn mounts on a non-stock kmember..
Originally Posted by Tuffguy610
Don't listen to ghettocruizer, he knows nothing about LSx swaps, especially for thirdgens. haha j/k, he knows basically everything. Whats goin on Justin?
When are you gonna check the car out?? I promise after your first ride you are gonna need to mod your car...
You had a V6 RS...rode in my TPI car...wanted a TPI. Now you have a stock LS1 car..and you'll ride in my modded LS1 car...and you want to mod. Its only logical. haha.
Wnts2Go10O: Let us know how you make out with the mounts. If you are still have issues, snap a quick picture so we can see whats going on.
Mr.Dudes description was spot on from what I can remember.
J.
