PRC 5.3 stage 2.5 heads...getting excited :)
Old 07-12-2007, 05:18 PM
DRTY LS1's Avatar
Default PRC 5.3 stage 2.5 heads...getting excited :)
I am starting to get pretty excited..I ordered PRC 5.3 stage 2.5 heads from TSP along with an underdrive pulley. Not the first time I've delt with TSP but their customer service is outstanding! Anyways...I currently have slp lid, k&n, smooth bellows, ported tb, hooker lts, hooker ory, GMMG, TSP Torquer V.3, dual springs, 7.4 pushrods. I've seen some good numbers with these heads but I really haven't seen any numbers with the V.3. I am anxious to install them and see what kind of numbers it will produce. Also people running these heads let me know any pros and cons you have come across! Thanks
Old 07-12-2007, 11:51 PM
shooter's Avatar
I'm installing mine heads this weekend, my cam, timing chain, and oil pump are completed. And yes as far as I'm concerned Texas Speed customer serviced is second to none!!! Good luck brother.
Old 01-30-2008, 06:10 PM
tkimrey's Avatar
To the op, let us know the gains you got from the heads. I'm in the market for some heads and I have the same cam you do...
Old 01-30-2008, 06:52 PM
01 BERGER CAMARO SS's Avatar
you wont be disapointed. I currently have these heads and I felt a much better pull than when I was using there stage 1 243's. Keep us posted
Old 01-30-2008, 08:45 PM
Redlinez's Avatar
I know I will be keeping an eye on your numbers.
Old 01-31-2008, 12:19 AM
Jon@Texas-Speed's Avatar
Thanks guys! We appreicate the kind words and continued support. We work extremely hard to provide customers with some of the best parts on the market and back them up with the best customer service and tech support in the industry. Extensive R&D goes into every product we sell to ensure you will be 100% happy with every penny you spend with TSP. Let us know what kind of numbers they put down. If you need anything else or have any questions during the install, don't hesitate to give us a call!
Thanks again!
Old 01-31-2008, 11:42 AM
Assman's Avatar
So are these PRC heads the same as the old TSP heads they replaced? Why did you guys go to PRC instead of keeping your own TSP heads?
Old 01-31-2008, 11:48 AM
NHRAFORMULA00's Avatar
DRTY, These are really a good set of heads.Before you install the heads half of the bolts that hold the rockers down need to be shortened because of the porting they stick out into the intake ports.I ground them down on a bench grinder untill they did not stick out into the port.Also i used Permatex #2 (non hardening )sealant on those same bolts,because the intake runners will pull oil through the bolt holes if you do not use a sealant.# 2 is non hardening and is used on old small blocks head bolts.Yo should get a nice gain of around 30-40 hp with these heads,GOOD LUCK.
Old 01-31-2008, 07:31 PM
mchdg86's Avatar
I also have those heads and with a tiny 224 cam and an auto I put down 402 rwhp. You will not be disappointed with them.
Old 01-31-2008, 07:58 PM
john563's Avatar
I gained 40rwhp with those heads in an A4. The price aint to hatefull either. Buy em' you won't be disappointed
