head bolt issue
head bolt issue
I'm building a 6.0L for my 98 trans am, I went to bolt the heads on today and the bolts are too long. they're the same length as the ones in my LS1, so i turned my attention to the holes in the block. The ones in the LS1 are a full 1 1/4 deeper than the 6.0l. I bought the block as a new casting last fall. Do newer 6.0L take different bolts? anyone else ever had this problem?
I bought it as a new casting last fall, i did the same thing i checked at the local parts store and gm, they both had the same part number.GM even told me the length and it is the same as the bolts i have.
