Prothane Bump Stop?
Old 07-14-2007, 06:31 PM
kicksZ28's Avatar
Question Prothane Bump Stop?
I HAVE A 98 Z28 AND NEED TO REPLACE THE STOCK REAR BUMP STOPS. DOES PROTHANE OR ANYONE ELSE MAKE THESE REPLACEMENTS AND IF SO WHO IS IT AND WHAT IS THE PART NUMBER? THANKS
Old 07-14-2007, 08:49 PM
Greggy's Avatar
why not use the stock gm part? They are widely regarded as the best for ride and handling.
Old 07-14-2007, 08:56 PM
kicksZ28's Avatar
Well, the GM brand runs about $30 each and I figured an aftermarket one would be a lot cheaper. I could probably check at some salvage yards for better ones i guess.
Old 07-14-2007, 09:03 PM
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
not to hijack, but does anyone know the part number for the stock GM one? I have one that roted away need a replacement but can't seem to find one.
Old 07-14-2007, 10:05 PM
Greggy's Avatar
47 bucks shipped for two from gmpartsdirect.com
Description: REBOUND BUMPER
Part #: 10164173
Categories:
Collision > STEERING/SUSPENSION > REAR SUSP
The material does fall apart after a while, but these bump stops allow you to hit them without feeling it and without upsetting the suspension as much as with harder or rubber type stops.
Old 07-14-2007, 10:10 PM
kicksZ28's Avatar
Thank You!
Old 07-15-2007, 01:32 PM
Greggy's Avatar
Thank LS1tech and the experienced people on it... I've done hundreds of hours of suspension searches!
You're welcome!
Old 07-15-2007, 02:38 PM
z28bryan's Avatar
Whats up
If there is a stiffer bumpstop, it would definitely both ride worse and handle worse. Because if you ever hit the bumpstop, you'd suddenly have no suspension travel left and nothing to cushion it making it pretty uncomfortable. The stock ones have a slight progression into being totally on the bumpstops and a little more cushion. Your tail end would be a lot more controllable with stock bumpstops.
Quick Reply: Prothane Bump Stop?
