What pistons are people using?
Honestly I'd go with Wiseco most likely. What sort of application is this for? You may want to investigate what material is in your piston..
https://ls1tech.com/forums/archive/i.../t-461396.html (Brian Nutter is in this thread)
https://ls1tech.com/forums/forced-induction/591175-piston-pick-one.html
My problem is time vs the best part for the job. Diamond reccomends a custom piston at 900rwhp-1000rwhp, but I wanted to get out and have fun with the car so I was wanting to find a on the shelf stocked piston to save time. In the end I filled out a custom diamond piston sheet and took care of it.
not anymore...broke the ringlands twice with no detonation (approx 800rwhp...12deg timing 11.0a/f and c-16)...the area is THIN where the top land meets the piston. My wisecos next to it are like an anvil next to aluminum foil. these were 402 stroker/boost pistons. A Sponsor has had the same issue as well but i will let them tell their tale if they want
